what is this hose called???
I noticed that this vacuum hose seems sort of flat and not very rigid (c'mon...grow up) . It is an '89 S2, as some of you will know. The car runs fine, but I just thought I'd replace it anyway as it looks like the throttle cable rubs the bottom of it. My questions is, what to I ask for when I call Zims???
Thanks.
Thanks.
I believe that hose connects to the idle speed adjuster that sits under the intake manifold. It is a fairly pliable hose even when new. Unless it is cracked and causing issues with engine performance, just leave it alone.
