How do I remove a stuck cylinder head?
My cylinder head is stuck. I have removed the 8 nuts, the 2 smaller bolts at the front, the manifold and h20 pipes. Even removed the waterpump in order to tap the head from below on the front 2 tabs. I have used a pry bar on the 4 different corners and the head appears to be loose on the exhasut side, oil and water leaked from it. The inlet manifold side does not want to move.
What next, your help will be appreciated.
