86 944 non-turbo, Timing belt broke! Are my valves bent?
944 86 non-turbo, 235,000 miles. Today the timing belt broke. Does anyone know if the cylinders have smashed the valves apart or if I only need to replace the belt and do the timing? I know that it is a low compression engine so I am hoping that I will be lucky.
Please HELP.
Peter
Please HELP.
Peter
UAE Rennlist Ambassador
Most probably you are not so lucky, but there are these "special cases" where one valve bends )or none)
Looks like you need to remove the cylinder head to find out.........
