Signal Trouble
Signal Trouble
I have a feeling this is a stupid question but I will ask it anyways.
The left rear turn signal on my 86' 944 went out, so I bought a set of 7506 bulbs to replace it. After replacing it I did a check and the signals worked, then after a short drive they were burned out. Also when I signal left the lights and the clicking sound is faster than normal. While the right turn signal still proceeds at the normal speed.
Anyone have any ideas?
The clicking speeds up when a bulb is out, maybe porsche did it to let the driver know a bulb was out...? Do you have the wrong type of fuse in? Look in the manual and make sure it is the right color/type.
I opened up the fuse box to check the fuse but I seem to be missing the fuse remover tool from the cover of the fuse box. Anyone know where I could find a replacement to put back on the fuse box?
