Lights issue PLEASE HELP!!
so I am having a lights issue. I don’t have hazards, I don’t have fog lights, I don’t have general gauge cluster lights, no parking lights, my headlights go up and turn on, but won’t go down when turned off. I’ve checked all fuses and relays, all good. Grounds seem good. I have tested (replaced with a known good one) headlight switch and ignition switch, both good no change. Any ideas? Some have said they had same issue but can’t remember cause. I’m sure it’s simple, but can’t figure it out. Help!!
PS: In the future, it is helpful for those looking into your problems if you mention the model year of your car (and if early or late if '85) as we can check against the appropriate schematic. In your case, this time, I checked against both the early and late schematic, and the answer is the same. You do not have power to the 30 terminal of your keyswitch.
The headlights are powered by the "X" bus, which is disabled when you turn the key to start, on account of the high current draw of the headlights, and different than the 30 bus which poweres the rest. I assure you that everything you describe as not working, including the headlight motor not lowering the headlights, are powered by the 30 terminal to the keyswitch. The headlights going up is powered by a different circuit.
appreciate your insight!Trending Topics
so I DO NOT have power to pin 30 on the headlight switch. You were right. So I’m trying to trace backwards through wiring diagram. It’s seems to be a red wire coming into fuse panel at L42, but not seeing red wire at L42 plug location. Am I missing something?
Ah, you are apparently reading from the Haynes manual. Do yourself a favor and burn it. Download the workshop manual from here:
https://www.uriarte.dk/porsche944/garage/workshop.html
or here:
http://p914-6info.net/944%20Manuals.html
The thick red wire from light switch terminal 30 goes to the fuse/relay panel at K31. You are on your way to solving this now.
or here:
or here:
or here:
This is what I’m looking at
