944 & 944S Forum 1982-1991
1987 944 Runnability Issue
Old 09-15-2024, 08:04 PM
JohnB4209
2nd Gear
JohnB4209's Avatar
Default 1987 944 Runnability Issue
Bought a 944 that was running with no issues after sitting for a few years. I brought it home and started getting it ready for inspection to get it on the road and went and got a full tank of gas after starting it up it seemed fine then went and got some other items. After starting it up the second time it started having an issue were when if you give it any throttle over an 1/8th it falls on its face. The engine still runs but it acts like its not getting enough gas (links to video of this from inside the car ) but as soon as you let off it goes back to idling fine.
Replaced the following items so far:
AFM
Fuel filter
Fuel pump
Fuel regulator
Old 09-15-2024, 10:13 PM
944M3
944M3's Avatar
Welcome to the club.
Sitting for a few years can result in many different issues.
I would start with checking for vacuum leaks everywhere, and I mean every single hose. Check for rips in the j-boot. Secure all clamps.
Check if water leaked from the battery tray to the DME (ECU computer).
Check throttle position sensor, IF your model has one.
Let us know how it goes.
Old 09-16-2024, 09:47 AM
walfreyydo
walfreyydo's Avatar
Classic vacuum leak symptom, but you also may want to measure fuel pressure to make sure thats within spec.
Old Yesterday, 10:41 PM
JohnB4209
2nd Gear
JohnB4209's Avatar
So removed the TPS cleaned and replaced the O ring. re-installed it and adjusted properly but still have the same issue. I would also like to mention I forgot to put in the original post that I have replace the DME relay with a new one. Later this week will be checking for a vacuum leak on everything.
Old Yesterday, 11:28 PM
944M3
944M3's Avatar
https://www.clarks-garage.com/shop-m...ect-19.htm#tps
Clark has a process to check the signal. Visual inspection is not enough. You will need a multimeter.
My suggestion is to check for vacuum leaks. If you don’t find any, I would proceed with testing the TPM signal.
I used Clark’s instructions to identify a faulty TPM.
Quick Reply: 1987 944 Runnability Issue
