Shifter replacement
Hello,
The shifter on my 200 000+ Km 944 is really loose. I believe I will need to change it.
While looking for a replacement part, I saw that there is one company offering a replacement with a bolt and bearings instead of the normal “pin”. Is it worth it? I can understand that on the long run it might prevent wear, but I don’t know if I should give the extra money.
Any opinion/advice?
thanks
Martin
Any opinion/advice?
thanks
Martin
Martin
Take a look at Only944.com , Kyle has a nice assortment of parts that will make your shifter and assorted hardware feel like new again.
I use all his bits on my SP2 car and i'm very satisfied.His customer service and support of his products is outsatnding !
Cheers
Phil
Cheers
Phil
The factory shift lever works fine and is what I use (replaced once) in my own car. What wears is the clevis-type pin connecting it to the long front-to-back shift rod, and the nylon bushing at the lever's base. Replace that bushing as well.
