Water Pump Query
08-11-2023, 07:17 PM
Water Pump Query
1984 944
About to do a water pump replacement. Does the timing belt need to be removed to do this?
C
08-12-2023, 08:22 AM
Quote:
Originally Posted by
Chargrod
1984 944
C
Oh, most definitely... also the balance shaft sprockets, the crank pulley, the timing belt covers, and most of your hair.
Good luck, and hope you don't break any of the water pump mounting studs...
08-12-2023, 10:24 AM
931guru
Also, check belt pulleys for bearing wear.
