Fuse Block Pins
Fuse Block Pins
I need help finding these wire connectors. 1987 944s Thanks
This is the connector I need to install new wires for fan speed resistors to fuse block
Slowly coming together
944s wire crimps
I need the metal crimp that the factory squeezed onto the wire harness that goes into the plastic blocks that plug onto the bottom of fuse block
I believe that the part number that you need is 999 652 456 22 contact spring...
If you want, I can send you one from an old wiring harness with a bit of wire attached that you can splice into your own harness... PM me for details.
I don't know that this will help but there was some information about these on the 928 forum: https://rennlist.com/forums/928-foru...lp-needed.html
It looks like a used part that you splice in might be the best choice, at this point.
ETA: This thread (https://rennlist.com/forums/964-foru...-fuse-box.html) has some good links to TE parts from Digikey and I've bought those connectors from them before; they're easily sourced and are cheap. The other ones that are NLA from Porsche may be much harder to source.
Good luck
Good luck
931guru (07-28-2023)
