My 86 944 will start, then stall regardless of throttle. Any ideas?
Hi
Recently, I replaced my head gasket along with the timing belt and balance shaft belt and now that everything is put back together I'm running into an issue. When I try and start the car, it will start but stall once the key is out of the start position and into the run position it stalls. Even with full throttle the car will stall. The car ran relatively well before this so I'm wondering what it could be.
Things I've replaced recently
-spark plugs
-speed sensor
-fuel pump regulator
-new vacuum lines
-spark plugs
-speed sensor
-new vacuum lines
