Hall Sensor
Hall Sensor
From what I understand, this is used to by the DME to set the timing/fuel scheduling. Is it true that when it fails that the DME will fail-safe to retard the timing? What are some noticable symtoms that occur when it fails. Mine currently has a crack at the bosch connector and its bad enough to see the wires. I am looking into replacing it. What does an engine that has a 'retarded' timing respond like?
ignition timing would be retarded 6 degrees from normal...so the engine would have a little less power
but if you are using low octane fuel, the knock detection would not work either...so you may also experiance detonation under load
My connector completely disintegrated. I was able to get the connection made, but its sketchy at best. The connecter for the sensor itself is ok, but the wiring harnes part is toast, any one have a part number for this harness? or a source for a whole engine harness? I have an 87 S
The sensors are pretty much an all or nothing deal. There'll be a short time of intermittent stumbles and stuff as it goes, but once it's out of spec, the car won't run at all. You see, as the sensor fail, the DME won't know how fast the flywheel's turning, so it won't know how long to keep the injectors open. It'll also miss the TDC trigger mark every once in a while, so it won't fire the cylinders correctly. And it won't be able to count teeth to find the spot to fire the #3 or the #2 cylinders on time... All of these effects will manifest itself as a car that run sporadically and stumbles.
