Rough running, spotty idle
Another question regarding my son's 87 944S. The idle is spotty at best. Saturday it wouldn't idle and died if I let off the gas. After about the third time running it for a few minutes, I backed it up into its parking space and it just started idling at around 750-800RPM like it was a kitten.
We bought the car last year not running. The PO said it was running fine and he drove to the doctor one day, came out, and it wouldn't start. Apparently it hadn't run for about 15 years when he bought it, and he did a decent list of things to it to get it running again. But not the timing belt or water pump, which would be (and was) my first thing to do.
We've done a lot of stuff to it to get it going, such as:
Timing belt, water pump, timing chain tensioner pads
New timing belt tensioner
New belts
New coolant hoses & reservoir
Newly rebuilt AFM
New plugs & wires
Rebuilt Bosch injectors
Fuel filters (in tank and in line)
Fuel pump
Rebuilt the notorious 3 prong male & female connectors for speed reference and Hall sending unit - the males were crumbled to dust
New Idle control valve
New vacuum hoses with venturi delete
New O2 sensor
It desperately needs a new exhaust, but the lack of idle and feeling like it is starving for gas at higher RPM's is getting old.
With as much as we've done, it has to be something simple we've missed. We double checked all electrical and vacuum connections.
Any ideas from those more experienced with these cars than me?
Thanks in advance!
New belts
Newly rebuilt AFM
New plugs & wires
Fuel pump
New O2 sensor
Thanks in advance!
