944 & 944S Forum 1982-1991
INTERMITTENT A/C BEHAVIOR???
Old Sep 17, 2021 | 03:08 PM
neversinksmith's Avatar
neversinksmith
Default INTERMITTENT A/C BEHAVIOR???
SO IM TRYING TO GET THE AC WORKING ON MY 86 944NA. thanks for all the help so far guys!
heres where im at:
replaced condenser, dryer, orings, pressure switch, and hoses. vacuum pumped evacuated. holds -30psi. 4 oz ester oil, 24oz r134 filled. low pressure side about 25 psi when running ac on at 70*f. . equals out at about 75 psi w car shut off. no leaks according to sniffer
HERES THE ISSUE IM HAVING
when i turn ac on its blowing wonderfully cold air. lasts for about 30 minutes then if i shut the car off and restart minutes later i no longer have cold. sometimes an hour later its cold air again. sometimes its the next day.
last night it went warm after 10 mins. i hit the defrost button for about 10 seconds and then i had my cold back again. tried this today after i lost cold and it didnt work. doesnt seem to be any rhyme or reason to it.
Im thinking expansion valve. any thoughts?
Old Sep 19, 2021 | 11:23 PM
Tiger03447's Avatar
Tiger03447
Good thinking. Probably the sensing bulb that rests in the evaporator has come loose and is not reading the exit air temp correctly...OR it's lost it's charge and the entire expansion valve assy needs to be changed out. I don't know what type of material that is inside the sensing bulb, to make the bellows on the expansion valve operate. It's also possible that the needle valve inside the expansion valve is stuck. Time for a change out and be done with it. Some expansion valves (in the past) used to have an adjustment to reset and "trim" the exit air temp by adjusting the needle valve, while in operation. Dunno about the Porsche units....
Old Sep 20, 2021 | 09:45 AM
neversinksmith
Does the expansion valve also shut off and turn on the compressor or is the compressor on all the time when the ac is on? Ive read conflicting info on this.
