ABS warning light
ABS warning light
Porsche 944 S2 1991
Recently my abs started to alarm regularly. Recently, this alarm is continuously present as soon as I start driving.
I measured my sensors and they turned out to be OK. All around 1000 ohms. Even so, I replaced them 1 by 1 with a good one. Except 1 (right rear) that was completely stuck.
I replaced the G20 relais
Then I replaced the ABS module with a good one. No difference.
Now I have also replaced the ABS pump with relays. Comes from a parts car. Not quite sure if donor part is okay, but looks better than the original one.
Now I don't know what to do anymore.
Does anyone have an idea what the problem might be?
(Apart from that one sensor, I replaced everything. I don't suspect the sensor as the ohmic resistance was good.)
Thanks in advance.
Thanks in advance.
