944 & 944S Forum 1982-1991
testing injectors - xposted
Old Mar 13, 2004 | 02:56 PM
adrian_jaye's Avatar
adrian_jaye
Unhappy testing injectors - xposted
Hi Fellas,
Was doing a procedure for my website. (Gleaned from the workshop manual) for testing injectors.
Well I got a prob. Firstly, I have no probs running or starting the car ! I can test for voltage as the manual says, but when I try and check for this "6 ohms" from the 5 pin plug of ballast resistors and terminal 2 of each fuel injector plug's I only see open circuit !
I've tried all combinations of pins, and I sometimes see 3.5ohms, but from the proper point I see "open" I've tested the resistance across the injector and get 2.5 ohms as correct.
I've got 2 pictures uploaded, pls have a look and tell me if I'm being a div !
the links are
www.playback.demon.co.uk/inject.jpg
www.playback.demon.co.uk/inject1.jpg
cheers
Ade
Old Mar 15, 2004 | 04:21 PM
adrian_jaye
> will be updating my website, with the full details,
> will advise when its on
website has been updated, feel free to pop along to:
http://www.playback.demon.co.uk/pors...odels/menu.htm
or for the full on effect !
laters
