944 & 944S Forum 1982-1991
Weird changes in power draw
Old May 11, 2020 | 09:09 AM
Noahjh's Avatar
Noahjh
Default Weird changes in power draw
I have this "issue", if you can call it one, where it seems as my alternator will randomly change load. This happens randomly when I drive and it generally creates a change in tone of the fuel pump, either brightens or dims the output of my headlights and also changes idle. Also, I have a squeaky serpentine belt which tends to squeak more when this happens, which is where I am getting the idea the alternator is "changing load" It doesnt really effect the driving in anyway, but definitley doesn't seem normal. My car is a WIP and probably could use everything fron vacuum lines, FPR, spark plugs and belts, but it drives alright as of now. Does this suggest some bad wiring from the alternator? Maybe a bad alternator? Im open to suggestions as clearly I'm grasping at straws here. Please let me know what you think of this situation, thank you!
