944 & 944S Forum 1982-1991
Low Beams only work when high beams are on
Old 03-17-2020 | 02:54 PM
Nick Bartleet's Avatar
Nick Bartleet
Default Low Beams only work when high beams are on
Hi,
I'm finishing up a 944 restoration and sorting out all the electrical gremlins one at a time. I'm struggling with my low beams not coming on as they should. The buckets rotate up, but curiously the low beams only come on with the high beams.
Any help form someone that knows what could cause this strange behaviour would be great!
Old 03-18-2020 | 06:08 PM
Breakaway944's Avatar
Breakaway944
Check the wiring to the headlights where the harness bends to plug into the headlight.
You can see a lot of wear on the wires at the bend
Quick Reply: Low Beams only work when high beams are on
