Race 944, How High?
What is the lowest height I can go on my track only "83 944. The tracks are fairly smooth that it will be used on. My spring and torsion bar (effective) rates will be around 350#. The car is around 2600 lbs. with me in it. I am using 16 x 8 wheels with 245 / 45's all around. Thanks!
Hates Family Guy
If I remember right, a lot of PCA zones require a minimum of 13" from the center of the front wheel to the bottom of the fender opening. If you go much lower than that you'll run into bad angles on the ball joints and things won't work the way they are designed.
Lower the rear so that the car is level.
What shocks and swaybars are you using?
