Porsche 944 clutch line
Recently my clutch master cylinder decided to vomit its brake fluid all over my carpet. While in the process of removing the master cylinder the fitting on the end of the hard line that goes from the master cylinder to the flex line that leads to the slave cylinder twisted off, ruining the hard line. Ian from 944 online sells a replacement for $100 which is pretty steep for me. I was looking at a universal -3an braided brake line like this: https://www.ebay.com/itm/Braided-Sta...e/381322935408 and was wondering what size fittings the master cylinder is, as well as the flex line, as well as the slave cylinder, so I can purchase fitting adapters. I'd like to bypass all of the clutch hard line and factory flex line if I can, and this seems like a cheaper and more replaceable alternative to factory parts. Thanks for your help!
Just make up a new hard line or get one at an Auto-parts store... Bring the old one with you and have them match it.. They are metric NOT STD adapters not needed... just buy the right fittings. If you end up having $10 into it, that would be allot. They sell bendable metric brake line in various lengths. Just out of Sheer Curiosity, What part of owning a 30 year old Porsche did you think was going to be cheap?
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/545x501/screenshot_2020_03_09_m12_x_1_0_to_an3_fitting_metric_adapter_used_for_clutch_and_brake_line_3an_ebay_da330c3521f6ad36a6ffe2c5bcb49fa7c26fbbd3.png)
they look like this, basically replace the flare fitting on the hard line with an adapter
