944 S2 - Oil in spark plug wells
Hi Guys,
my saga continues.
while changing the spark plugs (have not figured out the clicking noise yet, from my other post), I noticed that there was oil on plugs and in wells. See attached photos..
any thoughts on what might be the cause and fix?
my saga continues.
Yes, the cam cover has four large rubber washers to seal the spark plug tube from the camshaft housing.
Replace them and it's good.
Replace the rubber washers that go under each of the cover bolts, and do not torque them more than 7-10 ft-lbs. They are shoulder bolts and additional torque will not make them seal the cam cover any further, the rubber washers under each bolt does that.
Luis Garcia (09-02-2020)
my plan for this weekend is to clean out the oil out of the wells, put new plugs and wire set. Hoping that would stop the ticks..
I don't think I have the skills to open the valve cover, change gaskets and ensure that I close it correctly... Will have to take it to a mechanic for that job..
Lefty- it is a real easy job- the cover is just a magnesium part that is held down by some screws holding rubber bushings. There is a gasket around the outer edge and the 4 rings. This is a less than 1 hour job- you can do this. BTW, this was exactly the same problem I had on my Cabrio 2 years ago. I thought it was a serious issue, but it was so simple! When you torque the screws that hold the cover down, use the proper torque and no tighter. If you do take it to a mechanic this should be a very cheap and easy job. So don’t let them gouge you. As long as you are taking the cover off, inspect the wear pads that the small chain that turns the intake. Go to YouTube and see how to remove and install the cover- search “adjusting the timing of a Porsche 944 S2” by user irina25661. See cover installation at around 15:00 mark. Watch the whole video- super informative! But it will show you how simple this cover gasketing is!
The clicking noise is the fuel injectors, haven't heard a 3.L engine yet that didn't make that noise.
Kinda sounds like a lifter but it's not. Put a stick or something rigid between one of the injectors and your ear, you'll hear it clearly.
Where did you find the rubber washers ? I have an 83 NA 944 with the same problem
Where did you find the rubber washers ? I need them too. I have a 944 NA 1983
