944 & 944S Forum 1982-1991
944 s2 speedometer
Old Jul 25, 2019 | 06:08 PM
calin 52's Avatar
calin 52
5th Gear
Default 944 s2 speedometer
I'm the new owner of a 944 s2 cabrio year model 1990.I'had imported the car from USA and the speedometer is in MPH. Who can help with a answer to a simple question? the 944 s2 does it have a mechanical or electronic speedometer?
Old Jul 25, 2019 | 07:45 PM
Spring44's Avatar
Spring44
The early 944's have a conventional speedometer cable going from the drivers side front wheel hub to the rear of the speedometer housing in the dash. The square drive end of the cable extends through the back of the spindle; then through a square hole in the grease cap of the left front wheel, where it is held in place by a small c-clip. It is visible if you remove the left front wheel or the wheel center cap.
All 85.5's and newer models all have an electronic sensor screwed into the transaxle.
Old Jul 25, 2019 | 11:08 PM
PaulD_944S2's Avatar
PaulD_944S2
1990 Porsche 944S2 Cabs have an electronic NOT MECHANICAL speedometer.
Old Jul 26, 2019 | 04:19 AM
calin 52's Avatar
calin 52
5th Gear
Thanks for your quick reply.Very useful information.
Old Jul 26, 2019 | 04:22 AM
calin 52's Avatar
calin 52
5th Gear
Thank you so much,very useful information as I want to install a head up display to make the conversion from MPH to KPH.
Old Jul 26, 2019 | 04:24 AM
calin 52's Avatar
calin 52
5th Gear
I want to install a HUD(head up display) for making th.e conversion from MPH toKMH.Thanks again
