Strange 944 Running/ No Start Issues....
#316
+1 on verifying fuel pressure. If the pressure is normal but the car is still over fueling it’s another clue that leads to that injector driver circuit failing in some way. Just be careful not to over crank and thin out your oil too much.
The focus 9 dme is a great solution for anyone with a later car, the added option for an OBD module is also a neat upgrade.
in the meantime if you’re suspecting your DME relay is bad, I recommend going with one of their fuel pump relays with the built in diagnostics. It’ll save you a lot of time troubleshooting because it will answer a lot of those questions regarding the fuel system electronics and the ignition circuit.
944#447 (07-06-2023)
#318
have you checked any of the suggestions in my post yet ? it doesn't take a second to pull the hose off the FPV and check for a fuel leak from the fuel rail into the vacuum system. This was the cause of my identical issue on my 944S2. Excess fuel was leaking into the manifold prevented my engine starting and produced clouds of smoke from the exhaust .Replacing the FPV immediately cured the issue.
If you ask for help but don't acknowledge others posts with advice and suggestions or respond to their posts with a simple thank you you're likely to lose the help you've asked for. Even a tick on the like button tells the poster that you have read their post and appreciate their help and support
#320
i think he is asking for a forum thread explaining how to do it
944#447 you must try using the forum search feature and search for previous threads and not make others do that for you.
There are hundreds of threads on how to do this, I've written many over the years . it is really easy .
Just buy a cheap pressure gauge that has a rubber hose . Remove the big nut on the end of the fuel rail (don't lose the ball bearing inside. Connect the pressure gauge over the threaded end of the fuel rail . Crank the engine over and read the pressure . check what pressure you should have for your engine 2.5 or 3.00 bar from memory . Then watch to see if the gauge slowly loses that pressure which will tell you that you have a leak somewhere.
https://www.ebay.co.uk/itm/275282368...RoCGA8QAvD_BwE
#321
It seems that too many people come here expecting to be spoon fed, even after pointing them in the right direction, dont have the willpower to do some reading/exploration. This is a baseline expectation for owning one of these cars. If thats too much, probably not a good car to own.
peanut (07-05-2023)
#322
#323
why do you need to make up a hose ?
You just need a flexible rubber hose of a similar size to press over the fuel rail take off spigot . Its not rocket science .
The kit I gave a link to has everything you'd need for less than $12.00
if you make a post asking other owners for help and advice you need to come back and thank the posters ,answer any questions or give an update so we all know what the situation is and that we are not wasting our time . Its just common courtesy .
Now I have not read your post saying that you have given up ??? why not copy paste a link to that post in your answer .
Now saying that '''Don't give up......... there are some very experienced and knowlegable owners and Garage owners on here .....so nothing is not solvable ok.
My advice is to stop opening new threads about the same issue ....Stick to one thread so that people don't have to go searching through all your threads to find out what is going on.
that way nobody gets confused over which poster we are answering and you get advice specific to your problem .
walfreyydo (07-06-2023)
#324
Clarks garage engine troubleshooting (you should read through the whole shop manual when you have time)
https://www.clarks-garage.com/shop-manual/ts-01.htm
Measuring fuel pressure is important because it can reveal whether your FPR is bad, or if your pump check valve is bad, there is a blockage, etc. If the pressure is too high or too low, or if the system isn't holding pressure, etc. That way you arent making wild guesses about your injectors or DME when in actuality its your FPR, for instance. Honestly, theres no way of knowing if your issue is even related to fuel, unless we do the tests.
You said, the "engine is flooding with fuel"... well then its time to test that hypothesis with data. Fuel pressure is the most basic of basic tests when diagnosing fuel related issues. Its literally step 1. As you say, youve already wasted a ton of money guessing and replacing the entire fuel system, when you should have just done a fuel pressure test from the get go, examined the data and gone from there (following clarks garage fuel related tests of course). Other things would be to test the DME relay and the signals to the injectors, or the injectors themselves.
Could it be the DME? Yes, but you cant jump to those conclusions unless youve tested everything else or you have evidence that the DME is sending faulty signals to the injectors (which would be the indication your DME is bad). You do that through testing the injectors with a noid light (a kit costs $25) and again, this is all laid out on clarks garage.
peanut (07-06-2023)
#325
Thank you for being honest about that at least .....I'll not offer any further help or advice ...good luck
#326
A new DME fixed all my problems. There's something to be said about your first intuition [after extensive research]
Nothing was in vain, my car is now refreshed and running healthy. I also learned a lot about this car in the process, right off the bat.
It was frustrating but enlightening to say the least. Thanks to all who replied, and sorry to the original poster for any thread hijacking.
