Well, I have it "running" so I can move it around on it's own power now but am about to start making it mechanically sound. I'm about to start diving into the rear suspension/brakes first with an update to aluminum arms, Boxster brakes and convert to coilovers. I really dig the carbon bits but doubt I'll be going widebody but can certainly appreciate what you have done.
Its time to end radio silence here
Body is finally resprayed and Im assembling it.
Here is some fresh content about build! Re-assembled torsion bar tube
Applied heat shield on exhaust manifold side and tunnel
and heat wrap on manifold to minimize temperature
GAZ Coilovers arrived. These are more Track focused ones with adjustments (up to 6week production time if you want to purchase from them)
New brake lines in
Front brake tryout
Fender flare and wheel fitment check.
Need to find raised spoiler
Love those curves
Gas tank after respray. it was pretty rusted, but guys used acid to make it work again.
Gas tank installed
Brake lines under the hood
Front panel check. Need to make some changes unfortunately
And new episode is finally out on youtube channel!
A lot of things have happened!
I finally received new seats!
And engine is finally installed and hope to fire up soon.
Here is few pictures and new episode!
Enjoy!
Recaro Sportster CS with no air bags and heating Where to put it? hahah
Came back from trip and installed new shifter with custom shift **** from forged carbon. If you are interested in shift **** let me know as I produce them.
