928 Forum 1978-1995
Sponsored by: 928 Specialists
'78 Steering Rack Install: need help
Old 06-26-2017, 06:57 PM
hlee96
hlee96's Avatar
Default '78 Steering Rack Install: need help
I have been doing a complete suspension overhaul slowly (steering rack, reattached at the u-joint, tie rods, upper/lower a-arms rebuilds, new struts), I am having trouble lining up the steering rack-tie rods with the steering knuckle, elevation wise. I am using the spring compressors because I cannot get the A-arms/steering knuckle "high" enough to attach the tie rods.
Engine is out so no way to "naturally" push the suspension bits to align with a jack.
Also, I have to have the steering wheel turned to the left-counter clockwise in order to line up the tie rods to the steering knuckle (side to side) but the steering knuckle is turned so that the wheel is actually making a right turn.
Is there a trick or sequence of installation that I should be following?
Hopefully the pics will explain better than my description, thanks!
-Hoi
I tried to take this pciture showing that the knuckle is turned towards the right. *The steering wheel-rack is turned to the left so that I can place the tie rod end against the knuckle*
Tough angle to put the tie rod in the knuckle
I had the spring compressors on as much as I can compress but they still didn't line up, so I removed them for the night.
These are the compressors I borrowed from my neighbor
Old 06-26-2017, 08:01 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
The tie rod doesnt go out far enough??
Old 06-26-2017, 09:49 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,447 Likes on 1,373 Posts
take a piece of wood and gently tap the tierod pin towards the center of the car,
the pin will move,
then the part will fit.
NOTE early cars have shorter tie rods make sure your new parts match your old parts
BTW the tie rod end is made to move in all directions,
since its new it might seem stuck,
a little bit of force will realign it
Old 06-27-2017, 05:02 PM
hlee96
hlee96's Avatar
Thanks to the helpful hints. Stan is right of course. I didn't think about moving the pin directionally as it is built. Just a tap here and there and the tie rods are in and torqued.
Thanks so much Rennlist!
hoi
Quick Reply: '78 Steering Rack Install: need help
