928 Forum 1978-1995
Sponsored by: 928 Specialists
Anyone have a shock ride height adustment tool?
Old 11-19-2003, 07:29 PM
SNAG84Sa
SNAG84Sa's Avatar
Default Anyone have a shock ride height adustment tool?
I need to adjust the ride height after the install of new shocks and
upper and lower ball joints. I started to order a new one and then
thought that maybe one of you had one that you no longer had a
use for.
Old 11-19-2003, 07:39 PM
ErnestSw
ErnestSw's Avatar
In my humble experience a pipe wrench is by far the best and easiest tool to use.
Old 11-19-2003, 07:40 PM
ErnestSw
ErnestSw's Avatar
Old 11-19-2003, 07:44 PM
SNAG84Sa
SNAG84Sa's Avatar
That's a good idea, Ernest! I'm going right now and try it.
Old 11-19-2003, 07:56 PM
SNAG84Sa
SNAG84Sa's Avatar
cancel that idea, the pipe wrenches are either too big or too small. Please someone correct me if I'm wrong but with the ATV shock tool recommended on Nichols tip site, you don't have to remove the front wheels.
Old 11-19-2003, 08:11 PM
Normy
Normy's Avatar
SNAG- Don't use a pipe wrench! The spring perches can be adjusted with the same tool that you use to adjust springs on motorcycles.
Go to ANY motorcycle shop- they'll sell you one for less than $10-
Normy!
'85 S2 5 Speed
Old 11-19-2003, 08:17 PM
SNAG84Sa
SNAG84Sa's Avatar
Normy, I contacted a couple of shops in my area and they seemed to have no idea of what I was talking about. Do you have a name for the tool or a universal part # or better yet a particular motorcycle brand that uses the tool?
Old 11-19-2003, 08:23 PM
Randy V
Randy V's Avatar
An archive search yielded several results, here's one of them:
https://rennlist.com/forums/showthre...ghlight=yamaha
Old 11-19-2003, 08:31 PM
Normy
Normy's Avatar
No Snag- I actually found mine in the first motorcycle shop I walked into. I even told them what I wanted to do and they handed it to me.
This one is marked "Ohlins", I think they make a lot of mc stuff.
Here's a picture.
N!
Old 11-19-2003, 08:40 PM
SNAG84Sa
SNAG84Sa's Avatar
thank you Randy,
I'll give them another try--the locals before I order it from somewhere else.
I do believe on the Nichols site it list a shop that will send it to you for $.
Old 11-19-2003, 08:47 PM
SNAG84Sa
SNAG84Sa's Avatar
Normy,
You are marvelous!! Just marvelous! I'm printing as we speak. I'll go first thing in the morning. After reading that archive however, I'm wondering how easy/hard this is going to be. But what needs to be done has to get done.
Old 11-19-2003, 08:57 PM
John Veninger
John Veninger's Avatar
I use this one:
http://gmo1.com/site/itemdetails.cfm...=47&sort=Price
I never purchased from this company, so buy at your own risk
Old 11-19-2003, 10:19 PM
SNAG84Sa
SNAG84Sa's Avatar
Thank you too, John
The people at the Honda store are pretty cool. I believe I'll start there first.
Old 11-19-2003, 10:35 PM
Marc Schwager
Marc Schwager's Avatar
Getting the tool is the hard part :-). I ordered mine of the net. It was a shock adjuetment tool for an ATV. Once you have the tool, I found it pretty easy to make the adjustment. Just turn the front wheels one way then the other to get into both wheels.
On advice from the archives, I threw some penetrating oil on the threads the evening before I did it. After you adjust a bit bounce the car a couple of times to measure where you are. The nice thing about leaving the wheels on is you don't need the 25 mile drive to settle it after each adjustment.
Old 11-19-2003, 10:53 PM
SNAG84Sa
SNAG84Sa's Avatar
Thanks Marc,
I cleaned the threads real good with a lube-spray LPS that I borrowed from work, and I just put more of the same on it tonight in preparation for tomorrows height adjustment. Then on to Firestone with their state of the art Hunter DSP 600. It's an alignment rig that incorporates lasers and computers used to lift the car perfectly level. They then attach giant reflectors on each wheel which relay info back to the computer telling the adjustments that need to made. The tires and wheels keep the weight of the car on them the entire time.
Quick Reply: Anyone have a shock ride height adustment tool?
