Windshield washer pump mounting
As I'm getting my ww system working, I've finished pulling the resevoir, cleaning and rebuilding the tank and neck.
Now, I'm stuck on getting the pump under the hood mounted. I have 3 of the rubber nubbins, but as it's been 6 months since I've pulled it, I honestly cannot figure out how it goes back on the bracket welded to the fender.
How has anyone here done the mounting? I feel like using a really thick layer of GOOP and just glue it on the mount. Things are a bit tight down there, even with the coolant catch tank removed and the lines tied out of the way.
Cheers
Cheers
Definitely do not glue it on. Bad PO idea. The bracket makes it clear where the rubber nubs snap in, and you can see the holes from the wheel well. It is very easy snap in, just very tight. Attack from the bottom if need be.
