928 Forum 1978-1995
Sponsored by: 928 Specialists
Failed emissions BIG TIME!
Old Nov 18, 2003 | 09:23 PM
aircooler's Avatar
aircooler
Hello Donald,
I have no idea what "dilution" is or how it pertains to the emission report.
However I am picking up a few things here.
Old Nov 18, 2003 | 09:25 PM
Lizard928's Avatar
Lizard928
might I suggest installing an air fuel meter inside the car run off the O2 sensor, that way you can see if it is running rich
Old Nov 18, 2003 | 10:36 PM
worf928's Avatar
worf928
Originally posted by Donald
At the risk of repeating myself: I suspect the "dilution" reading is air:fuel. What is the target mixture on that MY?
Under the assumption that 'dilution' is in fact the air-fuel ratio - the values should be closer to 14.7 assuming that the engine was warm and that the 40km/hr test was at steady part-throttle. The ideal emissions value is 14.7. Ideal fuel-economy is 15.4 but, Cats of that day were not able to clean the NOx out of that lean a mixture. 12.6 is a max-power ratio that I've only seen at WOT at above 3-4k rpms. (I've seen a dozen or more 928s on dynos with EGAs. Most of them - that I've seen - don't get below 13 on a full-power run.)
Old Dec 16, 2003 | 12:08 PM
FeedNfrenZ's Avatar
FeedNfrenZ
I just bought my (1985) 928. I haven't had an emissions test done but it smells like it's running rich on fuel. I suspect the O2 sensor but I was looking at the Mass Air sensor and it looks as though it may be in backwards. Is there a right and wrong way put it in? Would it cause problems if someone had put it back in backward? What is the correct way?
Old Dec 16, 2003 | 01:09 PM
Fastest928's Avatar
Fastest928
mass air sensor
Marc
DEVEK
Old Dec 16, 2003 | 03:02 PM
Garth S's Avatar
Garth S
Watercooler,
By adding the O2 sensor, seems as if all the basics will have been covered.
There is an excellent 928 specialist in the NWest zone of TO (owner/operator) - he has tweaked numerous 928's into passing the Ont. emissions tests: some of these included Euro S4's without cats/O2 sensors.
If you wish a name/#/intro/etc., feel free to PM.
Old Dec 16, 2003 | 10:55 PM
aircooler's Avatar
aircooler
Garth, sent you a PM.
Hello Marc,
I know there are no crystal ***** (except at -20 putting up my Christmas lights), but is your suggestion of the MAS consistent with my readings, or do you think it is the next thing to replace? BTW I would like to put a link (with image) to DEVEK on my web site, is there a DEVEK image out there anywhere?
Merry Christmas,
WC
Old Dec 16, 2003 | 11:04 PM
Greg86andahalf's Avatar
Greg86andahalf
When making a list of tune-up parts, don't forget the smog pump (air pump) filter.
