928 Forum 1978-1995
Sponsored by: 928 Specialists
Front brake rotor removal -- HELP!
Old 01-21-2018, 11:46 AM
78Silver928
78Silver928's Avatar
Default Front brake rotor removal -- HELP!
OK, so I'm finally removing the aluminum ball joints from my '78, nuts all came loose without much trouble, but I can't seem to get the rotor off the hub. I can't get to the lower ball joint without removing it. The 2 set screws came out no problem, I just think it is rusted on. I've been hitting it with a hammer, so it probably needs to be replaced now too... any other methods you guys can recommend?
Old 01-21-2018, 12:15 PM
ammonman
ammonman's Avatar
There should be a couple of 8mm threaded holes in the hub of the disc. Screw a bolt in each hole evenly to force the disc off of the hub. Before installing the new disc brush a thin film of nickel based anti-seize paste onto the face of the hub to prevent corrosion and sticking.
Mike
Old 01-21-2018, 12:35 PM
granprixweiss928
granprixweiss928's Avatar
whack it with a hammer to break it loose. on the edge is best
or put a block of wood between the disc pad face and hit that.
Imo000
Captain Obvious
Super User
Imo000's Avatar
Try this.
Old 01-21-2018, 12:36 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
You can damage the bearing.
Old 01-21-2018, 01:40 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,256 Likes on 1,249 Posts
Turn the rotor around while spraying PB blaster on the inside seating surfaces,
then take a mapp gas torch and heat the the rotor have a hose or fire extinguisher handy and a wet rag the rotor should break free.
by using the bolts through the front face method
Quick Reply: Front brake rotor removal -- HELP!
