928 Forum 1978-1995
Sponsored by: 928 Specialists
Throttle switch removal questions
Old May 25, 2017 | 07:12 AM
siscogts's Avatar
siscogts
Default Throttle switch removal questions
Hi gentlemen,
Yesterday my mechanic/friend lento me his kts 300.
Everything quote working now, i found that hall sensor connector was giving intermittent contacts,then discovered that throttle cable has no wot open contact. Accelerator cables are ok as per wsm, so problem must lie in the switch. How hard this switch is to remove without pulling intake manifolds? Thank you.
Old May 25, 2017 | 07:26 AM
ammonman's Avatar
ammonman
So hard as to not be possible on the S4 and later cars. Sounds like it's time to plan and execute an intake refresh.
Mike
Old May 25, 2017 | 07:33 AM
siscogts's Avatar
siscogts
Forgot to say oy's a 92 gts... So ok,time to buy intake gaskets, injectors gaskets, and so on...
