928 Forum 1978-1995
Sponsored by: 928 Specialists
Washer Identity Puzzler
Old 05-24-2017, 11:05 PM
Daniel5691
Daniel5691's Avatar
Question Washer Identity Puzzler
Hi !
I have stared at PET until my eyes have crossed.
I truly think I am 3-D challenged. Can you please help me ID
where exactly these washers go?
Are 13 and 10 girdle washers, and 12 oil pan washers? I feel so stupid. Sorry.
Also, for some reason I have a note reminding myself to pick up PN 900 123 118 30, but I can't actually ID this part either. I do think it's a washer, maybe girdle or K Jet related ?
Old 05-25-2017, 06:19 PM
Randy V
Randy V's Avatar
That one's a crush washer:
http://www.autohausaz.com/search/pro...FUpNfgodLxgJOw
Old 05-25-2017, 08:30 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,707 Likes on 1,310 Posts
The exploded diagram in the WSM is more clear in this case RE: what goes where:
#10 is the thick M12 washer for the girdle for the girdle nuts, 10 of them. #8 in the diagram below
#13 is the thick M10 washer for the girdle nuts, 10 of them. #6 in the diagram below
#12 look like they're intended to go on the two short M10 studs outside the crankcase, over by the oil thermostat housing. #5 in the diagram below
900 123 118 30 is the sealing ring for the oil pan drain plug, and/or the oil cooler plugs into the block.
Old 05-25-2017, 08:32 PM
Daniel5691
Daniel5691's Avatar
Brilliant.
Thank you, gentlemen.
Quick Reply: Washer Identity Puzzler
