5spd shift lever setup instructions
Can someone point me to where in the wsm or other guide I can find the factory setup for my 5spd gear lever?
i think the dealer didn't set it up quite right after the tranny rebuild. While neutral is vertical, the gears seam too far to the left
Reverse
Second
Fourth
First
Third
Fifth
Reverse
Second
Fourth
First
Third
Fifth
WSM 34 - 8 pages c to i
Should be simply a matter of releasing the rear coupler shaft from the rear coupler, rotating to the correct orientation, and then re-clamping the rear coupler clamp bolt, to lock in that correct position.
