Need help with center console removal on '90 S4
Originally posted by John Veninger
fftopic:
Hi Ed,
We going to hook up on the way to the 2004 928OC Convention?
The GT needs to stretch it's legs again
fftopic:
Hi Ed,
Still remember the Kansas turnpike, do you?
Originally posted by Sterling
I think its a #10 right? I used a gear wrench... if you dont have a set BUY one.... they have em at sears... buy the gear wrench brand not the craftsman ones...
Still can't maneuver in there, though. Did you remove any of the ductwork? There's just not enough vertical room to allow for ratcheting.
Hallelujah! Now I'm pretty sure the rest of the center console removal will be easy.
Bet that little bastard of a screw will never go back in. Hope things hold together without it.
BTW, the front of the air bag cover does pry off, but I just took a peek and decided it wasn't going to help. Route to the screw was blocked by some sheet metal.
