Repairing 928 horns
JC Whitney always has some really interesting stuff.
Train Horn (sold individually, full set would go around $650):
http://www.jcwhitney.com/kleinn-horn...erid=c2545u0j1
The super tones are loud and sound like the original horns should have sounded - AND they fit like the originals (and last rather well). Avoid the too cheap options...
Alan
Alan
Am I testing at the correct points and is my meter
When the probes are not touching anything the meter reads 1
on the correct setting to check for this ?
If it is then I am fine since I am getting a 000 and 001 on each horn, but one doesn't work !
You want to be on one of the settings to the left (Clockwise).
Depending on the meter, it should read something like "Open" or "x" or "-" when the probes aren't touching each other (should be in the manual) and "0" when touching.
I always touch them quick to check when I turn it on because mine is old and sometimes the probe wires break loose.
I just checked on the web and it seems my "great" meter doesn't have the setting for continuity testing !
Joe Blo
i have this model...how do you test for continuity?REPLY
Adrian Buchanan
1 year ago (edited)
Joe Blo use the diode setting. the display will show 000 if the leads are shorted or if the circuit is complete.REPLY
2
Joe Blo
Adrian Buchanan
1 year ago (edited)
2
Found it thanks.
So if it is close to 0 when I test these two points on the horn then the circuit is fine ?
If only one horn works when depressing the steering wheel pad, then I might have a bad wire which gets to my other horn ?
To test for bad wiring, would I have to remove the horn pad on the steering wheel to test continuity from there to the other end ? Or is there a better way.
Both horns are connected to the same thing - if one works the other should work too... you can simply parallel them up. Practically - swap the connections first - if the same horn still works then its the other horn that has the problem not the wiring. If its not easy to resolve - high quality horns are not that expensive - I'd just get new ones...
Alan
Alan
Alan
Alan
Replacement 928 Horns
Anyone replace their OEM horn with an aftermarket horn with more presence?
A deeper/bolder/louder more masculine bellow?
Something that sounds testosterone filled German? Not estrogen fueled peeps?
Ideally something that requires no modifications?
