No power to the fuel pump and no spark to the spark plug
Chronic Tool Dropper
WHAT DOES THE TACH DO WHEN YOU CRANK ON THE STARTER?
If it jumps as you crank, CPS is likely (but not surely) OK, and you should be looking at power and ground connections for the EZK.
Received 1,569 Likes
Did anything 'interesting' occur just prior to these symptoms?
Do you still have no spark? How are you checking for spark?
What model year is this 928?
Thanks for replies , my car is 1989 928 s4.
After I replace the cps and ezk relay, the symptoms are still remain.
The tach does not jump when I crank on the starter.
As far as I know, the ground connection of ezk is a Brown wire. But, can u tell me What is the color of the power wire of ezk?
One thing interesting happened before the symptoms come out. I drove my car to the gas station, and I try to crank my starter after putting some petrol, but it did not start. And, I wait for an hour to get the car started.
There is still no spark, I pull out two HT cable from Bank1 and connect that two cables to two spare spark plug and then earth them, then I crank it, but it is still no spark.
Team Owner
What was the condition of the engine harness in the valley of the engine where it branches out for the ISV, CPS, and WOT/idle switch?
Does your '89 have the auxiliary CPS that is bolted to the throttle cable console?
