Brake Fluid Tester
Brake Fluid Tester
How many of you have a brake fluid tester in the garage? What kind of experience do you have using the tester? I have noticed the test results will differ if only the tip of the probes or the whole probes are dipped into the fluid.
The instructions to my tester say to dip the probes fully in.
Åke
https://www.youtube.com/watch?v=aLdMBVf7Ul8
Åke
I bought one last year and have used it on five cars. Seems to be accurate although one brand new bottle of fluid showed 1% moisture. Bottom line, when my tester says replace the fluid, I do.
