928 Forum 1978-1995
Sponsored by: 928 Specialists
what wire is this??
Old Nov 6, 2003 | 02:52 AM
urnotthesameina928's Avatar
urnotthesameina928
Question what wire is this??
Can anyone identify the purpose of this wire???Here is a photo of a wire near my jumper post..long and square plastic covered... Its the wire to the upper left hand coner that is not connected to anything.. Am i missing a connection here or is it just an extra feed from the harness that means nothing..
1986.5. USA model. running rich and low on power...Dave.
Old Nov 6, 2003 | 02:54 AM
onebad928s's Avatar
onebad928s
i believe mine went to the A/C compressor
Lou
83 928 5speed
Old Nov 6, 2003 | 07:43 AM
Jim @ EuroWerks's Avatar
Jim @ EuroWerks
Well' it's a bunck of red wire near a cooloant hose. How about a bigger picture?
Old Nov 6, 2003 | 07:47 AM
Dozman's Avatar
Dozman
Jim,
It's early morning for me. Look at the top left corner. It looks like a faded clear plastic square cover that is being used an insulator for a solderless connector that goes to the a/c.
Old Nov 6, 2003 | 07:52 AM
Jim @ EuroWerks
I thought that was th bottom of the engine block. I don't see the a/c. since that is a coolant hose and no big red wires go to the a/c it's probably going to the back of the alt.
Old Nov 6, 2003 | 09:40 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
If you are missing the plastic cover over the jump start terminal, you can expect to have serious problems sooner or later. Water will get into the connections and cause corrosion...
It always helps greatly on wire identification if you give the wire color.
Old Nov 6, 2003 | 11:28 AM
Sean79 5spd's Avatar
Sean79 5spd
Looks like the terminations on the 3 red wires are already very corroded. I had to solder new rings on each of them. I also bought the plastic cover. It is cheap.
Old Nov 6, 2003 | 05:47 PM
onebad928s's Avatar
onebad928s
wow you guys are blind!Not the red wires but the long plastic rectangle in the pic is what Dave means
Lou
83 928 5speed
Old Nov 6, 2003 | 06:21 PM
Dozman's Avatar
Dozman
Less beer equals better vission.
Anyways, your right. It's in the top left corner, faded discolored plastic cover.
Lets try it again. Name that part
Old Nov 6, 2003 | 08:36 PM
TAREK's Avatar
TAREK
I have it on my 86.5 as well. Not connected to anything either...and the wire coming to it (thin...may be 20 AWG) is blue...or may be green...It was dark and I looked at it with a flashlight
Old Nov 6, 2003 | 09:20 PM
GT Jackson's Avatar
GT Jackson
Me too. Green wire to male plastic bayonet connector, with no connection. I do have a connection to my A/C compressor so I can't figure this one.
Old Nov 6, 2003 | 10:03 PM
Eric G's Avatar
Eric G
Ditto. Not connected to anything.
My guess is it's part of the standard wiring harness used in US and Euro cars, and it's a specific connection not used in the US cars.
Old Nov 6, 2003 | 10:06 PM
urnotthesameina928
yes its green and the platic connector I found was not connected to a friends 86 as well. He was complaining of lagging response from his engine as wellso I went over and we looked over his engine.. I would guess that its for an optional accesory or a test point for the tech in all of us..I do have the cover not to worry as I was going in there to clean things and coat with my Pro gold pen. Next is the relay board and connections from the tempII to the brain. Maybe car is not receiving all info it should from my almost new tempII. Maybe thats why she is running so rich
Old Nov 6, 2003 | 10:14 PM
Thom1's Avatar
Thom1
Cool
That's the weinersnitzel and pretzel warmer, or blender accessory feed for futbol tailgating and such!!!
Old Nov 6, 2003 | 11:01 PM
onebad928s's Avatar
onebad928s
Dave,
that wire is part of a harness from the electric air valve to the a/c compressor. Dont worry theres 2 choices of connections, both connections are on the same line.The one in your pic(my 83 uses) and theres a simple male to female connection that the newer cars use.Shop Manuals 87-68 air conditioning.
Lou
83 928 5speed
