socket size
socket size
I'm replacing the rubber sleeves in the injector housings. What size allen head socket is needed? 79 OB, K-Jet
James
James
Trick question!
I think the injector takes an 11mm. It's a standard size.
But... Unless those have been out recently, got anti-seize sometime, or both, turning the injector will just tear a hole in the metal cap. Be prepared to use a Vice-Grips on the bigger "cap" section to get it to turn.
