928 Forum 1978-1995
Sponsored by: 928 Specialists
No lights.
Old 12-22-2016 | 02:45 AM
Mrspencer's Avatar
Mrspencer
Default No lights.
Anyone have any idea or leads, I'm having an issue with my s3 no reverse lights, and yes I have checked the bulbs, also no front marker lights, I have not checked the marker lights as of yet.and finally every now and then my passenger head light won't come on when activated, after 2nd or 3rd try they both work, have the cree lEds in it did samething wIth the stock ones any advice would help.
Old 12-22-2016 | 02:50 AM
Kiln_Red's Avatar
Kiln_Red
What model year and originally intended market? Auto or standard?
Old 12-22-2016 | 05:24 AM
The Forgotten On's Avatar
The Forgotten On
If you have no marker lights your headlight switch could be faulty.
Borrow or buy a good used or new part and check that first.
Old 12-22-2016 | 11:53 AM
davek9's Avatar
davek9
Is this S3 an auto or manual, makes a big difference for T-Shooting the Reverse lights?
Front Marker lights or Fog and do the Fog lights work?
When doing the LED headlight update you will need to replace the Fog light relay with a standard 53 type else you will have issues with the HI beam and Fogs.
Marker lights are fused (Left and Right side), check you fuses and clean them all while your in there
edit: Headlight (one not working all the time), first check the bulb and clean all the wiring especially the ground (swap bulbs too?) if all checked still no joy could be the Headlight relay $
Dave K
Old 12-22-2016 | 08:38 PM
Mrspencer's Avatar
Mrspencer
Default No lights.
[QUOTE=davek9;13830160]Is this S3 an auto or manual, makes a big difference for T-Shooting the Reverse lights?
Dave K[/QUOTE the car is an 85 5spd
Old 12-22-2016 | 08:44 PM
Mrspencer's Avatar
Mrspencer
Fogs work drl works rear quarters work no frnt side markers. Will check that lamps ground put new leds in her cleaned the connectors and coated them in di electric grease, still once in awhile the passenger light won't light up on the first or second attempt. It always comes on though.
Old 12-22-2016 | 08:47 PM
Mrspencer's Avatar
Mrspencer
Dave K
Thanks for your time and knowledge🤔🤔😣
Quick Reply: No lights.
