More efficient vacuum routing...
All -
Asking for clarification and efficiency...
I want to double check the vacuum line routing as I am not sure what I disconnected to replace was correct anyway. Also, the Decel Valve (attached to the side of the throttle) was already removed and I am not putting it back.
So, the attached pdf shows it all...
1-3) I do not know which devices these are and need help identifying. Can I use a combination of Ts and Ys and run all three of these off of one tap on the throttle body?
4) This is connected to the line that feeds the heater valve. It has two vacuum ports. One is currently connected to '3' above. Not sure what its official name is and what it should connect to.
5) Vacuum advance on distributor
6) Fuel damper
---> can 5+6 run off of one tap with a 'Y' off of the throttle body?
8) This is what I have currently set up to feed both fuel pressure regulators on the backside.
I believe I have all of the brake master side connected up good to go.
Thanks all - sorry for the inconvenience of the pdf.
-scott
6) Fuel damper
-scott
#1 & #2 are for the charcoal fuel vapor recovery system.
#3 I have no clue, the PET shows thermo valve.
I would reroute all lines as they are shown in the factory manual. I reckon the engineers grouped some things together but used dedicated vacuum lines to other components for a reason.
Following the diagram above is a good start.
Realize that each vacuum source in the airguide/throttle body has different behavior depending upon the throttle plate position. Route the lines any way you want, but make sure that each vacuum-operated end-point is connected to the correct source.
Scott,
I did a full photo-documentaion on my 84 L-JET which should have the same routing as yours when I replaced my engine last year.
Here is a link to all 7MB of photos and video, in case that would be useful.
https://www.dropbox.com/s/a8xsvaepaj...hotos.zip?dl=0
Attached below are most of the photos from the vacuum routing. Good luck. The vacuum routing was one of the things I was most nervous about getting right.
Thank you for sharing! This is going to be very helpful - I am like you, because of the nature of vacuum in the engine and its variability, I knew there was a "Right Way" to do it!
Thanks again -
-scott
Thanks again -
-scott
Hey Kiln_Red -
I am not sure as the original decal was either removed or painted over. The color is the same in the repaint however (as the underhood, door jambs, etc. are the same).
I have been told that is "Kiln Red" but I am not sure. Rob mentioned that they did not start including paint and interior codes in his records that he uses for options lists until later, so we were not sure.
Is there anywhere else on the car I might could look to verify?
-scott
-scott
