You mention a good price considering what's wrong with it. So what's wrong with it? I'm curious what kind of trouble you're in.
Looks nice in pictures though!
Lost of small stuff. The largest being the internal fuel pump is failing(per prior owner) Car doesn't run right, currently.
But the list is a follows;
1)All tail light bulb sockets need to be replaced(probably just order 2 harnesses)
2)Coolant overflow is cracked
3)Key light button on the dash locks doors but doesnt unlock
4)Driver power seat button is broken
5)Dash lights are dim
6)Needs upper intake manifold refresh
7)Oil flanking both sides of the thermostat housing
8)Window guides worn
9)Rear brakes need replacing
