928 hood width?
Thinking of getting a hook on workshop light, and minimum width 1230mm. I know car width 1836mm, so maybe with our wide fenders the hood too narrow for attaching light (magnetic mount lights no good obviously!). Thanks for info
Adrian
The weight of a light would be a factor as the hood is light, and hood struts are not able to take much extra weight without dropping, as a consequence of that.
Perhaps sling a wider light from the ceiling above, by a strap each side attaching to each end of the light just under the hood??
In past using fluorescent light it has pulled hood down with weight. The light I had in mind is led so much lighter, but I would have used prop if too heavy. Back to lighting drawing board...
