HIGHWAYMAN: Bringing the Devore 928 back from the dead
#226
The Parts Whisperer
Maybe those larger rear brakes will work for you but it didn't for me, even with my F50 14" brakes up front. It gave me way to much rear bias
#227
Really? Did you use an adjustable bias controller?
I wish I had talked to you about this before I bought them, although I can use them for another build.
So as far as I know the car has S4s in the front.....would you use S4 rears as well, or???
Also, the car has a Tilton cockpit adjustable valve if that helps. Thanks Mark
#228
Update:
Spoke to Mark, who advised against the larger rear brakes, so ordered some S4 cores for the rear.
Oh well, interestingly, the Turbo Targa came with no rear brakes (seems to be a pattern on projects I buy), so they are not a total waste.....
THANK YOU MARK!
THANK YOU MARK!
#230
^ yeah and shameless plug for Mark who is having a half off all used parts sale until Xmas.....the new S4 cores were cheaper than the brake pads!
#231
While I wait for parts, I wanted to revisit the sway bar / handling characteristics thing we were talking about.
For those that don't want to go back a few pages, I opined that a full hard sway bar in front and a full soft (or no) sway bar in rear was a cure for oversteer as far as I know.
Opinions? Comments? Why does the car have so much oversteer in its modified state?
#232
. Anderson in my opinion tended to drive around any handling shortcomings. So your car now is unique and totally untested the only way to really sort it out is at a track .
. Obviously your Autocross set up will be different than that for the big tracks. You may like using some over steer either power induced or by lifting to rotate the car in slower tight corners.
. If you want to be inundated with comments go over to the race forum where Kibort is still allowed to post.
#233
Jim,
Great insight here. You just brought up the untested part, which I had only half been paying attention to. That is a MAJOR factor in this build. I am sure Devore knew what he was doing to some extent, but he never got to actually TEST his theories.
As Mark said to me the other day, there will be a ton of things to fix and adjust even after the first drive, which confirms to me that AX is the best place to start even just to make the car a runner.
For sure it will behave different on the track; any car can be a champ at under 60mph......
#234
I think the stiff front/ stock or no rear swaybar combo will work well. I also think the car will put a lot of load on the rear tires because of the weight transfer from side to side, but then again alot of horsepower will do that too so whatever haha. If its anything like my z, it will be a little more dependent on good tires than other cars.
#235
#236
I don't mind the throttle steer. The Camaro has that characteristic; Could controllably drift around a complete autocross course in that car like Ken Block, LOL.
#237
The Parts Whisperer
Very interesting.....but it my understanding that a functioning Weissach isn't compatible with ultra wide tires????
#238
I think he had OEM rubber bushings throughout, correct? As far as feeling easier to drive, that's cool, but do you recall if you were as fast lap time wise in the yellow car as in the white car?
#239
The Parts Whisperer
still I'm only talking a second a lap or so.
#240
The Bud Hart / Devore project was I believe designed for open road high speed rallies and thus the huge fuel cell, less emphasis on weight reduction or ride heights. The 90 mile Silver state Classic for example has three turns.....the infamous Narrows. .I drove it in a dually with trsiler and GTR inside the last two years
.I always wondered if the much bigger frontal area made sense ??? Or a big rear wing . But still a fun project, Even if race cars are NEVER done !
