928 Forum 1978-1995
Sponsored by: 928 Specialists
OB instruments inop
Old Oct 29, 2016 | 12:52 PM
jheis's Avatar
jheis
Default OB instruments inop
I have an intermittent problem with the dash instruments on my '82.
If it sits for a while, sometimes the instruments don't work. The turn signal light is on steady, and tach, speedo, etc are dead.
Other times the speedo reads about 20-30mph & fluctuates (not with actual speed), but the tach doesn't move and other instruments are dead. Usually, it clears itself after awhile - but, sometimes, not.
I assume I have a sticking relay, but which one?
James
Old Oct 29, 2016 | 01:25 PM
GlenL's Avatar
GlenL
Your car has general electrical arthritis.
At this point, every contact point has corrosion if you haven't cleaned it recently. Look for the list of grounds and start there. Then move on to all connectors. People (me included) find the Deoxit spray to work well. Ya take something apart, sprtz it, wipe it, and put it back. For connectors, do a few on/off/on cycles. This also works for all the relay pins. Get the connectors on the CE panel, too. Fuses will respond to a spin in-place.
Your worst-case issue is having problems in the pod itself. That's a PITA to fix and the foil (if not newer) is crisp. I'd expect that you'd have problems there that will be very touchy to fix. The connectors at the pod go onto folded flexible circuit and that gets crispy over time. It's tempting to say "do the pod" but, personally, I'll fix everything else before digging into that and hope it gets good enough without opening that kettle of fishy barreled monkeys.
Oh yeah, an '82 isn't an OB.
Old Oct 29, 2016 | 10:50 PM
erwalker's Avatar
erwalker
I also have an '82 (OB!) and had a similar problem. Turned out to be one of the smaller wires that connects to the positive terminal directly at the battery. Pulled them all off, cleaned them and tightened them up really well and all went back to normal.
But Glen is right too (except for the OB comment!) - Deoxit works really well and you need to clean all the connections every year. For whatever reason, these cars are corrosion magnets.
Old Oct 30, 2016 | 12:42 AM
GlenL's Avatar
GlenL
Originally Posted by erwalker
But Glen is right too (except for the OB comment!) .
Nope. OB is pre-1980. We all want to be in the club.
I'm here to help.
Old Oct 30, 2016 | 09:33 AM
curtisr's Avatar
curtisr
You might be able to reach up from underneath and wiggle the connections but if you do, do so carefully. The connectors have little tabs to secure them in place and breaking them won't help.
I have the same problem as you and recently took the Pod off in order to deoxit the connections. While you're there you can replace any bulbs if required.
A search of this forum will lead you to plenty of discussion, tips and how-tos.
Old Oct 31, 2016 | 08:38 PM
jheis's Avatar
jheis
Thanks.
Connections at the battery are "scotchbrighted" shinny clean - no joy.
The car has lived its whole life (except for road trips) within 60 miles of San Francisco, so corrosion is (generally) not a problem. Grounds get attention whenever I'm "in there."
This problem has happened before and it usually clears itself - eventually. Which is why I suspect a sticking or "slow" relay.
I really hate driving with no working gauges (especially fuel & temp).
James
Old Oct 31, 2016 | 08:41 PM
ROG100's Avatar
ROG100
Basic Sponsor
Shortly I will have the complete rear circuit foil for the 82 to 84 cars 8>)
Old Oct 31, 2016 | 09:13 PM
erwalker's Avatar
erwalker
Seriously Roger? That is great news. Mine is good for now but I've always wanted one "just in case"! Actually I'd replace the old with the new and keep the old one as a spare!
Will you let us know when you have them?
Old Nov 1, 2016 | 02:38 PM
R.Pires's Avatar
R.Pires
Hi Roger,
This is great news! Im sure it will solve a lot of the dash "gremlins"!
I assume this will work on all the 82-84 cars, US or Euro.
Please let us know when available.
Regards my friend
Old Nov 3, 2016 | 07:49 PM
jheis's Avatar
jheis
I was fairly confident that this was not a ground problem, since my car is not exposed to corrosive conditions and I'm pretty good about cleaning grounds whenever I'm "in there."
However, after some gentle nudging from member Wayne Strutt, I figured I had nothing to lose and decided to check the grounds at the steering column support and pull the pod and check the connections.
I remember doing the grounds at the steering column support before and they looked good, but I pulled it apart and shined up the chassis contact point and all four connectors with a scotchbright pad anyway.
I started to pull the pod and thought maybe I should reconnect the battery and check the gauges before I went any further. Hooked up the battery and the gauges are working again! So, I guess it goes to show that you can't tell the condition of an electrical connection by looking at it... Buttoned it up without having to pull the pod.
Of course, the voltage gauge still doesn't work, but that predates the problem with the other gauges.
Any suggestions as to why the voltage gauge doesn't work? This also started out as an intermittent problem, but the voltage gauge hasn't worked at all for about a year...
James
Old Nov 3, 2016 | 08:01 PM
Wisconsin Joe's Avatar
Wisconsin Joe
Well, you might pull the pod, pull the cluster, then pull the plastic off the cluster. You can get to and clean the gauge connections.
My temp gauge was doing this, and cleaning up the contacts from the plastic to the gauge itself got it working again.
Or it could be the gauge itself. When (if) you pull the cluster out of the pod, you can test it.
Old Feb 18, 2022 | 11:35 PM
Acscorpio9119's Avatar
Acscorpio9119
So I need help guys...desperately, a grown man here just about to start crying, I took out my cluster off my 928S 1983 cause I wanted to replace some bulbs, sure enough I was not able to fit new sockets to led bulbs,, screw it I gave up! I cleaned the connectors and reinstalled the speedometer , sure enough NOTHING works anymore as needles, THEY ALL USED TO WORK prior! Temp gauge and fuel JUMP to TOP!!!! speedometer, RPM, battery and oil needles ARE NOT MOVING ANYMORE, PLEASE HELP !!!!!!
Old Feb 18, 2022 | 11:39 PM
Acscorpio9119
WHERE CAN i SEND A 928 CLUSTER TO BE REFURBISHED AND HOW MUCH ?
