Different Flag Mirror Versions - Education
What about these?
@Rexxus : It looks like the connectors are actually still there, attached to the posts, and underneath all that crumbling coating. The wires are just soldered into the barrel connectors and it looks like yours have detached. I'll bet you can dig out the connectors, clean them up, and resolder them. I don't have a good solution to the insulation bit, however.
Good luck
Good luck
For what it's worth, I'd bet a nickel that those are the same connectors that are in the standard 14 pin connector that are used in various places around the car. I'm pretty sure Roger has them.
As to the connector above, I think you're going to want more surface area contacting the post. I have never measured the size, but standard bullet connectors can probably be made work, if OEM is troublesome.
Good luck
Good luck
