78 #209 alternator fix replace what is my best option?
I have moved this wheel and nothing happens. any other suggestions for the lamps? I will be taking the pod out one more time I will post a pic.
See my thread for alternator problem.
https://rennlist.com/forums/928-foru...lp-needed.html
I had mine bench tested and was told it was fine. All my problems disappeared when I replaced it.
I do not want to replace the alternator as I want to keep this car original as possible. Is there a way to fix the old alternator?
on a good note I got my dash lights working so now I can see my speedometer at night.
How did you sort the dash lights, for my memory bank please, and thanks in advance.
Ok last effort to figure this out.
My alternator repair guy had some voltage regulators on his shelf with the same model number. They were used but I thought what the hell I will give it a try. installed new regulator very simple 2 bolts 3 wires. with the new voltage regulator my alternator light went out after I started the car (always stayed on before). Alternator is still not charging even at high RPM.
Here are some volt readings.
engine on at idle - Alt exciter wire at alt. 9.9V
engine off key set to on position - Alt exciter wire 10.16V
engine off key set to on position - Big Hot 12V cable on ALt. 11.5V
engine off key set to on position - Jump post 11.79
engine off key off - Jump post 12.18V
[UPDATE] The alt light on the dash pod does not go on anymore when turning the key to on position. I put the dash pod back together and it stopped working or it only worked for a min when I tested it after installing new volt regulator.
Any suggestions?
Any suggestions?
