928 clutch master cycilender replacement
i am trying to change the clutch master cylinder on my 78 928, i have removed all the linkage from the inside. i can not get my arm up to the master, what do i have to remove to get there, i have the shop manuals but i can not find anything on r&i of the master
Team Owner
the easiest way is to remove the master cylinder for the brakes,
then the booster,
then remove the clutch master.
with all three of these parts out of the car.
you can buy all three of them and install brand new parts .
It will be a very good investment for many years to come .
Make sure to use ATE brake fluid
then the booster,
