Anyone know spider coloring?
While I'm struggling with my fuel strainer, thought that I would clean up my tank spider. Once I get past the body shutz/undercoat, some parts appear to be black other parts look body color all with a consistent red oxide undercoat.
What is factory for 1978 928 Euro?
Archive Gatekeeper
Black.
Archive Gatekeeper
The cradle in the pic got sent out for powdercoating so I don't have a good feel for what the the undercoating was or if it had undercoating. Tank cradles often have a lot of corrosion so if there was a factory undercoat or galvanized dip or something (I doubt it), it wasn't very effective. I'd guess they were just dip painted in whatever chassis black Porsche was using at the time. All idle speculation, take it for what it's worth.
the cradle that holds the fuel tank in to the underside of the car.
Archive Gatekeeper
My understanding is that non-metallic paint colors were painted top and bottom, after the schutz was shot, and the schutz was light-gray in color. Metallic cars are painted only from above, with variable overspray in the engine compartment and wheelwells. Schutz before paint, in either case. Cradle shouldn't have had undercoating on it, at least not from the factory.
I assume understated = autocorrect of undercoated?
Chronic Tool Dropper
On Jim C's '78, the fuel tank cradle is definitely black. There are foam pads between the "arms" of the cradle and the plastic, which look like they started out as non-black but became black (paint?) at some point.
mine is black, and never been painted. Build date May 78
My black 79 which is mostly original paint is not painted on the underside. It's gray. In fact there were areas under the booster and by the coolant reservoir that are bare galvanized still. No paint or primer!
The tank strap was black, no undercoat. Definitely appears to be a quick dip. No primer or galvanizing that I recall.
