Running GTS value?
Hi Guys I have a '94 GTS auto with 15x,000 miles. Midnight blue metallic. Runs and drives well, but will need cosmetic work. Paint is 60& good (body has no damage). Interior is medium grey leather, and with some work can be 80% good. 12-way seats, ac blows cold. Regular wear n tear.
GT motor installed has newly manufactured cams from Todd at Greenbay, and ~80k miles. Upgraded tensioner (Porkensioner) and upgraded water pump (no-fail), as well as torque tube flex plate clamp. Runs strong & idles perfectly. Good torque. Transmission & PSD work perfectly. Driving-wise the car is as good as any other on the road. Just cosmetic issues. Any thoughts on the value of the car? I have the original motor I replaced because it had been poorly repaired and ended up with aluminum under the lifters. Bores of the GTS motor and crank are good, no damage. Heads are good as well, though they have been machined. Looking for a value assessment of the car, and the extra parts if the buyer is interested.
I'm raising a small child so I cannot give the car the attention it deserves.
