LSD ?
LSD ?
My '80 feels like it has LS as it's most noticeable when I leave the driveway when it's cold. My VIN says it doesn't but there is always the possibilty that it could have been added by one of the PO's. Is there a code number on the diff?
Archive Gatekeeper
I'd be impressed if a PO stamped some sort of code on the tranny case when adding a limited slip. Early LSD-equipped transmissions had a /12 stamped into the case after the model # to indicate LSD. Not sure when that ended.
You may already know this, apologies if so.
