Interior Temperature Bezel Repair?
#78
#79
The short answer is yes. That is an easy geometry for a 3D printer. Also since it gets covered in vinyl or leather the surface finish would not have to be as smooth as something like the face of the temperature sensor housing.
The issue with a part like this is it's size and structure. Both of which would make the part cost high. Printing this in something like ABS plastic may not result in acceptable structural rigidity. There are 3D printers however that embed continuous fibers of fiberglass, carbon fiber or Kevlar in a nylon casing. The result would be a part stiffer and lighter than the original. The price however would be $$$. But that is today. In 3 to 5 years it will be very affordable.
So is this part not available either new or used?
#80
Nate: "So is this part not available either new or used? "
Nate, Nice job on those temp bezel's
Regarding the trim surrounds, pretty sure Doug_B from Canada still needs one and Alex mentioned he needs several. Have not seen a good trim surround for sale in years for the OB's either on it's own or in a parts car. What would $$$ be per unit if making lets say 10 of them ? T
#81
#82
Pic above is from Mokka and she's up in CT. If nobody chimes in with dimensions, I'll get over to the shop later today and take measurements/pics of surround from Just Peachy (1979 interior). IIRC it's a foam type material wrapped in vinyl. Never took one apart so not sure of sub-structure. T
#83
So I just took a WAG at the dimensions based on the pics and assumptions of the part thickness. And if an ABS part could be designed to be strong enough and assuming any heat used to affix the vinyl isn't hot enough to deform it, then my guess is that a 3D printed part like this could be offered in the $100-$200 price range. Going to a fiberglass printed part would put it in the $300-$500 range.
#84
Ok, I know absolutely zero about 3d printing, other than what I've seen on here (and a few other places).
So is it possible/feasible/reasonable to make a metal frame and then have the 3d printer lay a layer of material around it?
#85
There are also printers that can mix materials. The Markforged line of printers can embed carbon fiber in nylon. The result is a part like I mentioned above that can be stronger than aluminum. So the need to try to 3D print material around metal is eliminated.
The state of the art high end 3D printers today are laser sintering metal powder to produce metal parts with material properties akin to cast metal. Koenigsegg 3D prints their One:1 tail pipe directly in titanium. However the printer they use is on the order one million dollars!
#86
I created a new thread here to discuss the center trim piece.
https://rennlist.com/forums/928-foru...-interest.html
